Need help with wheel spacers
Old Oct 2, 2009 | 02:20 AM
reddakota34's Avatar
reddakota34
Default Need help with wheel spacers
Well on my 99 dakota i have 3inch body lift with 3inch suspension with stock rims and 33-12.50-15 tires. And right now the front stick in further then the rear bye the looks of it. So i was thinking 1/2inch spacers in the rear and a 1inch spacers in the front. And it should be evan corect?
Old Oct 2, 2009 | 03:08 AM
tamcnally's Avatar
tamcnally
From: Salisbury, Vermont (home) - Lima, Ohio (school)
well if you say the front already stick out further. then why would you put a bigger spacer on the front?
Old Oct 2, 2009 | 09:15 AM
reddakota34
No i said the front stick in further than the rear.
Old Oct 2, 2009 | 09:44 AM
1999R/T's Avatar
1999R/T
measure your distance and figure up the difference. Measure inside wheel lip to lip on the wheel write it down. Then measure the front same way, make sure your wheels are as straight as you can get them. It wont be exact, but close enough for wheels spacers. And while we are at it, why space the rear? Just space the front 1/2 inch if that appears to be the difference, unless you just want mud throwing clearance
Old Oct 2, 2009 | 10:58 AM
tamcnally's Avatar
tamcnally
ok. your right you did. i misread it. my bad.
Old Oct 2, 2009 | 01:17 PM
varsis's Avatar
varsis
front tires usually stick out further for a better turning radius. I have a 2" difference with my new axles.
Old Oct 3, 2009 | 12:23 AM
reddakota34
Well i have my torsion keys turned up all the way thats why i think they are closer to gether then the rear.
