97 Dak rough idle..sometimes..suspect MAP
I recently put in a new fuel pump. I thought that might have been causing the idle variation. The pump was bad, wouln't hold prime.
Still has rough idle that come and goes.
cleaned and adjusted the throttle body, idle solenoid, etc.
Checked for vaccuum leaks, can't find any.
Can a MAP sensor go bad part way without throwing a code?
