TPS problem P0123 high volts (please help)
My truck idles but the second you touch the gas and let off it dies. I checked the TPS conector with the key on and had 5.1 v at the supply and 5.8 v at the signal wire. I traced the wires back to the harness and nothing seemed to be chafed. I heard that a short from the horn curcit (12v) could cause this so I pulled the horn fuse but nothing changed. I also heard the the clock spring could cause this so I disconeccted the battery and then disconeccted the clock spring and still nothing changed.
I am looking though the manual right now to get an idea where I may have a wiring issue.
If anyone else has had this problem and knows something else that I should check please post.
Thanks
Phil
Thanks
Phil
UPDATE!!!!! Started pulling the harness apart didn't see any chaffed wires put everything back together and put the new TPS is and it was 5.09 volts supply and 1.00 volts signal and at WOT was 4.1 volts. So I guess the TPS is ok now?
HOWEVER the CIL is still on and still giving me code P0123? I have no idea what is wrong right now I had the battery disconnected and the computer was disconnected so the computer should have reset.
If I'm overlooking something someone please chime in. I need to get the truck running asap bikes are sitting outside and it is going to snow. Apparently this global warming thing is missing MN
Ok, with the TPS disconnected you should have roughly 5v on the supply wire and roughly 5v on the signal wire. Also make sure that the sensor ground is good. When the TPS is connected, the voltage on the signal side should never go above 4.7 or 4.8 and if it does it will set the voltage high code.
