Leaking coolant/water from somewhere...HELP
Old Oct 12, 2009 | 11:36 PM
cscards's Avatar
cscards
Default Leaking coolant/water from somewhere...HELP
97 Dakota 2wd, v6........
Started to overheat a couple weeks ago. Pulled over, shut it down and popped the hood. Steam was comming out and you could hear a whistling, almost like a steam engine. It seemed to be almost out of water so I let it cool down, added water and drove home making to watch the temp......Once I was home, water was comming out pretty good.
Okay, so I figured no brainer, must be the water pump.....went through the process (not fun) of changing the water pump and guess what.....As soon as I started adding 50/50....the water started to run out again. I crawled under to try to see where it is comming from and it seems to be comming from above the water pump, but back behind it. I cannot see exactly where it is leaking from and I am not sure what is back there. Checked oil and it seems normal (due for a change).
Where could the water (leak) be comming out?
Old Oct 13, 2009 | 08:15 AM
Me&MyMopar's Avatar
Me&MyMopar
Did you check to make sure all the hoses are good? If not, I'd check there first.
Old Oct 13, 2009 | 09:51 PM
primus454's Avatar
primus454
Hoses, timing chain cover (cracked or gasket), freeze plug.
Old Oct 13, 2009 | 10:19 PM
cscards's Avatar
cscards
Default Update - -
Fixed.......after everything, it was a pencil size hole in the bypass hose. When I changed the water pump, I checked it but obviously not enough. The hole was in the underside of the hose. If you've changed one, you know what a task it is......
For anyone needing help: remove fan and housing, remove water pump, remove alternator, unbolt and move the a/c compressor out of the way. You will be able to access the clamp from here but if your is anything like mine......you'll need to remove the 4-5 bolts from the bracket that hold the alternator and other items........Now you can access the $4.99 hose that has caused you over 4 hours of work.......
Like any other first time repair....I could probably to it again in less than 1 1/2 tops.......
Thanks for the ideas and luckily it was nothing more serious.....
Old Oct 14, 2009 | 04:30 PM
diright's Avatar
diright
Default bypass hose
replacing that during a W/P is an automatic
