2004 dodge dakota car stereo question
cd was stuck in stereo, disconnect ground battery, took out fuses, stuck tweezers in car stereo and yes finally hit dashboard and cd came out. Now cd won't go into player at all.
Basically what and where is the reset button?
denitareed@sbcglobal.net
You reset the unit when you disconnected the ground from the battery. Finding the reset button on the unit won't help this problem. The CD player very likely has internal damage and it either needs to be repaired or the unit needs to be replaced. I would suggest finding a good car audio shop and taking the unit to them for a repair estimate. If you replace it with aftermarket unit, nowadays you can get a good one for around $200 to $250 installed.
Jimmy
Jimmy
