What R The Differences Between Dakota 4.7 n Ho. 4.7 In The Jeep Overland
Old Oct 20, 2009 | 01:47 AM
Bertpod's Avatar
Bertpod
Default What R The Differences Between Dakota 4.7 n Ho. 4.7 In The Jeep Overland
How can I Gain a TRUE 30 Hp n 40Trq??? Then I
Remembered about the "4.7 Ho Jeep OverLand".
I want to know where the 25 Hp n 35 Trq
comes from in that 4.7 Ho Jeep Motor OverLand..
Is it jus in the Heads, Cam n Intake???
How much is Different between these 4.7s??
Will the "OverLand" parts Bolt on the Dak 4.7??
If a "OverLand 4.7" bolt on wont happen, how
can I gain Real Power.. Not 8 Hp FlowMater Crap..
Thanx,
Rob
Old Oct 20, 2009 | 03:57 AM
wingerak92's Avatar
wingerak92
I think the Intake, and cams bolt right on. But the intake isn't available anymore. You have to go with the 2008 Intake, which is better anyways. Airram has them.
I am not sure on the heads.
A superchips tuner 3865 is good too if you jsut go with the intake, jeep cams (also known as HO Cams), and a 70mm Throttlebody, CAI, and exhaust.
Anything more, like a 72mm Throttlebody and custom cams and such, you can get a SCT Tune from Hemifever taht will work much better.
Old Oct 20, 2009 | 02:25 PM
bpark8824's Avatar
bpark8824
They are completely different. There was A LOT of changes to the HO 4.7 to gain that power...
http://www.wjjeeps.com/ho_engine.htm
^Thanks to fox672 for originally posting that^
And it came in more things than just the Overland.
