Djm 3/5 inch drop ?
Old Oct 20, 2009 | 10:41 PM
tireburning dakota's Avatar
tireburning dakota
Default Djm 3/5 inch drop ?
hey debating on getting the djm kit control arms and shackles for my 2wd reg cab, i want to go low, do you think i can also use the drop springs with the control arms to go lower and how much will i get?
Old Oct 21, 2009 | 03:32 PM
batman13's Avatar
batman13
you could yes,
your alignment would be beyond unrepairable though. up to you
Old Oct 21, 2009 | 09:04 PM
batman13's Avatar
batman13
make sure you get the mininotch and shocks
Old Oct 22, 2009 | 07:06 AM
tireburning dakota
Thanks guys for now I will just get the kit , what shock absorbers do u reccomend for the drop
Old Oct 22, 2009 | 01:35 PM
MTN13's Avatar
MTN13
From: Hometown= Highland Michigan School= Lima Ohio
you could use drop springs in the front with the control arms, and still be able to align your car back to spec. With the control arms your really just moving the center point of the wheel further up in the wheel well and it does not effect the alignment angle, now if you add in drop springs it will effect the alignment angles and you will need to do an alignment on the truck, (but you should do it anyway whenever you replace suspension parts). You can also put blocks on the back with the shackles to drop the rear more.
Old Oct 22, 2009 | 05:26 PM
batman13's Avatar
batman13
i currently have no aftermarket shock experience.... ive heard good things about nitro and toxics for dropped trucks
