Sway bar bushing options
Old Oct 21, 2009 | 08:02 PM
bpark8824's Avatar
bpark8824
Default Sway bar bushing options
I am going to replace the FRONT swaybar bushings and when I was looking at NAPA's online it has 4 options..
http://www.napaonline.com/masterpage...d=7&SubCatId=2
1. w/ 1 1/8" Bar Diameter To Arm
2. To Arm w/ 1.40" Bar Diameter
3.To Frame w/ 1.18" Bar Diameter
4.To Frame w/ 1.30" Bar Diameter
What one does the Dakota use?
Also I was wondering who sells polyurethane ones? And how much more are they?
Old Oct 21, 2009 | 09:00 PM
batman13's Avatar
batman13
go to autozone, they sell energy suspension poly bushings, best you can get,
and NAPA is ridiculously expensive for everything
Old Oct 21, 2009 | 09:48 PM
bpark8824's Avatar
bpark8824
Do you know how much poly bushings run?
Old Oct 22, 2009 | 06:34 PM
batman13's Avatar
batman13
they arent real expensive that i know
im gonna run energy susp. polys in my Linked rear suspension if i ever get around to doing it
Old Oct 22, 2009 | 09:43 PM
bpark8824's Avatar
bpark8824
Anything special to know when using poly bushings? Never used them, usually just use OEM replacement ones, but with all the nasty roads I drive on, I want to replace them with a quality part because I plan to have the truck a long time.
Old Oct 22, 2009 | 10:07 PM
batman13's Avatar
batman13
nope, not as far as i know,
you can install zerk fittings and grease them with a poly grease if you plan on abuse like i do
but i dont think yours are gonna see the kind of beating i'll be dishing out...i'll see what kind of info i can find
