Large Evap leak.
Old Nov 27, 2009 | 11:56 PM
tallhamer88's Avatar
tallhamer88
Default Large Evap leak.
So my 2001 Dakota 3.9L, 72k miles
Check engine light came on today, Code p0955 i believe i kinda forgot..
but it stands for large evap leak..
Any idea which one it could be.. I checkd my gas cap it seemed tight. So that easy fix its not..
Any help Would Be Great..
Old Nov 30, 2009 | 02:52 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Don't find that code on the list. Double check the number. Check here for the list. https://dodgeforum.com/forum/1052121-post2.html
Old Nov 30, 2009 | 03:25 PM
deranged's Avatar
deranged
Replace gas cap and then start checking all your vacuum hoses for cracks or leaks. Charcoal canister is a good area to start. (under driver seat along frame)
Old Nov 30, 2009 | 03:34 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
its probably a crack on one of the vacume hoses, on my dads 3.9 it was the hose near the cap under the PDC (right behind the battery, PITA to get to) you can cut it down in length and put it back on a couple of times, but eventually you need to replace the hoses . . .
Old Dec 1, 2009 | 04:37 AM
Ramrat's Avatar
Ramrat
had the same thing on my 99 3.9. was the fill tube between the tank and body, had a small rust hole in it. it's a dealer only part for about $200 and a quick do-it-yourself fix. that may not be it on yours, but here in the rust belt, the guy at the dealership said it is kind of common. good luck
Old Dec 2, 2009 | 01:10 PM
2000DakotaOwner's Avatar
2000DakotaOwner
Default Error Code, Large Evap Leak
I have the same code on my 4.7L but everything seems to work and run fine for now.
