97 Dakota Transmission Fluid change
Old Nov 30, 2009 | 11:01 PM
Senate427's Avatar
Senate427
Default 97 Dakota Transmission Fluid change
My buddy owns a 97 Dakota 4x4 V8 automatic transmission with about 158k miles on it. In 8 months he drove 30k miles and I think time for a transmission fluid change. I would like to do the tranny fluid change for him since transmission shops are rip offs with their BS. Anyway I need know the right steps to do the change.
questions>>>
1. What type of transmission fluid should I put in his truck and how many quarts need to be added?
2. What type of filter should I buy and does the gasket need to be replaced?
3. What else should I replace during the transmission change?
4. Should I mix any Lucas tranny fluid in the truck?
Thanks
Old Dec 2, 2009 | 02:29 AM
Crazy4x4RT's Avatar
Crazy4x4RT
You will need ATF 3+
For the filter they all are the same. But get a Cork gasket. The rubber moves around to much. DO NOT use any RTV.
Automatic Transmission: 42RE and 46RE 9.0L-10.4L "dry fill" (dropping the pan and replacing the filter takes about 4-5 quarts)
Old Dec 3, 2009 | 01:40 AM
Independentfool's Avatar
Independentfool
ATF+4 is newer, better, and compatible.
rubber is a much better gasket IMO. cork is crap. i will never use cork.
dont put in any additives. ever.
Old Dec 3, 2009 | 02:41 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I never had any luck with the rubber. ALWAYS moved on me. But I don't even use the cork.
The TRUE best gasket is dealer. Which is plastic with a O-Ring style seal on it.
