need new waterpump, change anything else??
Old Dec 23, 2009 | 11:27 PM
willyb8's Avatar
willyb8
Default need new waterpump, change anything else??
well the truck i bought 3 wks ago starting leaking from waterpump. luckily its still covered under the 30-day powertrain warranty. is there anything else i should have done while the waterpump is being done? it has 82000 miles on it.
Old Dec 24, 2009 | 12:48 AM
varsis's Avatar
varsis
Change the tstat and have the system flushed.
Old Dec 24, 2009 | 07:08 PM
wewanaplay's Avatar
wewanaplay
82,000... probably needs balljoints too, LOL
Old Dec 24, 2009 | 11:57 PM
dbilik's Avatar
dbilik
Change the little hose on top of the water pump when you have it changed too if its a 3.9 or 5.9.
Depending on when it was last done, you can also change the upper and lower radiator hoses while you have the system drained, both the magnum and 4.7L.
If it is a magnum, Change the o-ring on the bypass tube.
Old Dec 25, 2009 | 12:00 PM
RoaminGnome's Avatar
RoaminGnome
Im gonna agree with varsis, tstat and a flush and you should be good. a GOOD mechanic will check the hoses as they do the work and replace as needed. Now with those being as rare as winning lotto tickets Id mention it when you drop it off
Old Dec 25, 2009 | 08:40 PM
Repo's Avatar
Repo
Yes,have the T-stat replaced and the cooling system flushed too.I have the v-6 in mine and it is a real pain to change the stat in mine so have it done with the pump.
Old Dec 27, 2009 | 10:25 AM
willyb8's Avatar
willyb8
thanks
