P1781 & p1737
Old Dec 29, 2009 | 02:22 AM
cbassj8's Avatar
cbassj8
Default P1781 & p1737
P1781 P1731. I had theses two codes pop up. I cant find out what they exactly mean, It has to do with the transmission. Anybody know what they exactly mean. Thanks for your help in advance.
Old Dec 29, 2009 | 08:33 AM
tristatehunter's Avatar
tristatehunter
I found these on the website below. Sorry about the caps.. I just copied and pasted
http://en.allexperts.com/q/Chrysler-...sion-codes.htm
P1737-MS SOLENOID CIRCUIT
POSSIBLE CAUSES
RELATED RELAY DTC’S PRESENT
INTERMITTENT WIRING & CONNECTORS
MS SOLENOID CONTROL CIRCUIT OPEN
TRANSMISSION RELAY OUTPUT CIRCUIT OPEN
MS SOLENOID CONTROL CIRCUIT SHORT TO GROUND
MS SOLENOID CIRCUIT SHORT TO VOLTAGE
MS SOLENOID INOPERATIVE
TCM - MS SOLENOID CIRCUIT
P1781-OD PRESSURE SWITCH SENSE CIRCUIT
POSSIBLE CAUSES
PRESSURE SWITCH INOPERATIVE
OD PRESSURE SWITCH SENSE CIRCUIT OPEN
OD PRESSURE SWITCH SENSE CIRCUIT SHORT TO GROUND
INTERMITTENT WIRING & CONNECTORS CONDITIONS
OD PRESSURE SWITCH SENSE CIRCUIT SHORT TO VOLTAGE
TCM- (OD)
