are my brakes bad? lol
Old Jan 7, 2010 | 03:38 PM
thunder98110's Avatar
thunder98110
Originally Posted by Josh Abels
i heard that when the ball joints start to go bad they make that kinda sound
easy way to check bj's is jack the truck up and take a broom handle or something and try to lift the tire up kinda like your prying it up. if you have alot of play or noise they might be going bad.
Old Jan 7, 2010 | 04:32 PM
Josh Abels's Avatar
Josh Abels
nothing happened when i did that which is awesome cause those are expensive, but when i did lift it up and spun the tire i heard that high squeak again im thinking my rotors are kaput, which i would rather replace than the ball joints, so i have an excuse to switch over to slotted and drilled rotors and ceramic brakes and brakes are fairly easy
any idea on those bushings in the pic anyone? would rather replace all the bushings at the same time while ive got the sway bar off, so i can have it alligned once
Old Jan 7, 2010 | 04:51 PM
thunder98110
if your rotors are warped you would notice while breaking the pedal will actually come back towards you or they could just be rusted.
Old Jan 7, 2010 | 05:43 PM
Josh Abels's Avatar
Josh Abels
i dont think they looked warped but did notice a significant amount of rust of the outside edge, i think i will prolly end up replacing them at some point anyway, because i want ceramic pads and awesome rotors, if only i had enough money to go 4 wheel brembos lol
Old Jan 7, 2010 | 05:48 PM
varsis's Avatar
varsis
could be a wheel bearing...
Old Jan 7, 2010 | 08:42 PM
CSCustomCars's Avatar
CSCustomCars
The sway bar end links come in a kit that includes all washers the bolt and nut and the bushings.
Do your brakes first, then Look into those bushings and a possible wheel bearing issue. I say do the brakes first because your wear markers could be rubbing your rotor when you step on the brake or not.
If you spun the wheel off the ground and heard the noise that sounds like a wheel bearing.
Jack up your truck and spin the wheel again, but when you do, grab the control arm. If you feel a roughness when it spins, it's a wheel bearing.
Old Jan 7, 2010 | 08:52 PM
Josh Abels's Avatar
Josh Abels
would a bad wheel bearing possibly cause the truck to pull to the left if its that side the sound is coming from, my step dad and i are gonna bleed my brakes prolly sometime this weekend to see if that could be my brake problem, but i know the bushings for my sway bar are where one of the sounds is coming from
Old Jan 7, 2010 | 10:45 PM
CSCustomCars
Um yeah i suppose a bad wheel bearing might cause a slight pull, but thats probably your alignment. A bad wheel bearing will usually cause a humming on the road a lot like tire noise, which is often mistaken for a bad wheel bearing.
Old Jan 8, 2010 | 01:30 AM
varsis's Avatar
varsis
mine caused a pull to the left but than again there was nothing left of the bearing... lol.
I wish I could find the pic...
Old Jan 9, 2010 | 12:45 PM
Independentfool's Avatar
Independentfool
bleed. bleed. bleed. get ALL the old fluid & air out of the system.
