Swap a 08 4.7 into a 2000 4.7???
My brother totaled his 08 larmie slt 4.7 dakota in 2009 and bought in from the insurance company. It has 24,000 on the motor and trans.
He will sell it to me at cost, but I really only want to swap the motor-trans and seats into my 2000 4.7 auto SLT quad which I love. It has 195,000 on the orignal motor and trans. Is this a possible swap or are the harness and electrical problems to much for a 36 year old shade tree mechanic??? I love the 08 HP, Torque, MPG and anti-sludge. Let me Know Jamie:icon_shrug: |
I'm not familiar with the 4.7's but my guess it that the basics of the engine block will be the same. But hopefully a BUMP! To you thread will get someone else to comment on it. Also you may want to try posting a thread in the 3rd Gen and see if anyone over there knows.
I believe you will need to swap the engine and computer because there is a difference in the crankshaft position sensor tone rings, but I'm not 100% sure.
Hopefully dbilik will respond because he knows a lot about these motors. |
Originally Posted by 95_318SLT
(Post 1947305)
Hopefully dbilik will respond because he knows a lot about these motors. I am not aware of which version 4.7 came in the '08 Dakota, but the blocks have pretty much stayed the same. The motor itself has been improved upon in some versions, with HO cams and pistons, a better crank I believe, and some of the newest ones have 16 spark plugs and get better MPG. You can get your VIN and call the dealer, see what you have. This is a research topic in itself. Regardless though, you can put the motor into your 2000 QC, and if the gaskets are all good in the '08, they are reusable, all rubber. Meaning you will end up being able to swap the tone ring off the crank for about $62 or so if you do it the right way. Meaning you use new connecting rod bolts, $54, since they are TTY and new mopar sealant to seal the upper and lower block, $8. I'm workign on a HOw-To write up for this, but I haven't completed it yet. https://dodgeforum.com/forum/2nd-gen...y-2001-qc.html There is a little info there. If you need specifics once you get started I can help you out and let you know which tools you will need to start hunting for and which tools you can plan on modifying to make work. Everything is metric. I can show you how to freshen up the old block too, :), but once you strip it down you probably won't want to do much with it. |
thanks so much
I am always amazed by the knowledge and sharing on truck forums, I always learn so much. It looks like I will buy his 08 and make the swap this spring. I have a unheated garage and it is 20 degrees here is Michigan. Thanks again, I will give an update when I am done.
Jamie:icon_angel: |
When you take apart the original motor do it carefully. The block is still good obviously, and if still in spec could be freshened up. Typically they go cheap though only because it is so expensive to work on and get parts for in comparison to say the old Magnum motors. And if you really get in a jam with the swap I am 4 hours away, but I am sure you won't have any problems.
