2002 Dakota problems - knocking and sqeaking
Old Jan 13, 2010 | 07:08 PM
Arbitratur's Avatar
Arbitratur
Unhappy 2002 Dakota problems - knocking and sqeaking
I have a 2002 Dakota. The transmission went on it not that long ago. So I ended up getting my tranny rebuilt. I had pulled it out and put it back in by myself. A couple days after i started noticing a slight "squeaking" noise. Almost sounds like something needs grease or something to that effect. it has gotten gradually worse and now does it pretty much all of the time. Doesnt affect how it drives though. Just today, probably about a month later, it started to knock. it started about half way through my trip to work this morning. It only does it while it is in drive, and has only gotten worse while keeping on driving it. The steering wheel shakes a bit while in the higher speeds as well as a louder knock. and last but not least, it seems like about 1/2 the times i am going into 3rd gear it revs a little extra before switching. This did this before the transmission went also. Fluids are now clean since the replace and are at good levels. Anyone have any ideas about any of this. sorry about the whole paragraph haha.
Old Jan 14, 2010 | 02:28 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Maybe a drive-shaft is hitting something or a bad U-Joint. Sorry but you got to go underneath and take a look.
Old Jan 14, 2010 | 05:44 AM
Arbitratur's Avatar
Arbitratur
yeah i jumped under there yesterday but didnt see anything offhand so i figured id post on here to figure out where to start looking
Old Jan 14, 2010 | 06:36 AM
deranged's Avatar
deranged
Better get under there and make sure everything is tight. Converter bolts, bellhousing bolts, U-joints, everything. Sounds as if something is not in proper alignment and if it gets worse with more speed and is now knocking you could be causing major damage somewhere.
