fan and pulley wobbling...new waterpump?
Old Jan 22, 2010 | 03:24 PM
bobodean's Avatar
bobodean
Default fan and pulley wobbling...new waterpump?
After noticing a squealing kind of noise from under the hood, I check and see the fan and the pulley it is connected to are wobbling.
Does this mean a new water pump is needed or are they separate?
Old Jan 22, 2010 | 06:54 PM
deranged's Avatar
deranged
Yup, new water pump is needed.
Old Jan 22, 2010 | 11:38 PM
Spidamantnmc's Avatar
Spidamantnmc
same happened too me. you need a new water pump
how many miles are on it? you might wanna do the timing chain as well
Old Jan 24, 2010 | 07:19 PM
Repo's Avatar
Repo
Yes,Replace it before it goes into the radiator!
Old Jan 24, 2010 | 10:42 PM
dakota19762's Avatar
dakota19762
Yes, get a new water pump or your fan belt will slip off as mine did. Then you get to see how your truck looks on a tow-truck. Doesn't look too good.
Old Jan 24, 2010 | 11:01 PM
packarat's Avatar
packarat
Same as above except for one thing; it looked real good on that tow truck .
Seriously my belt ended up shreaded and wrapped around the pulleys, big mess. Not to mention losing power steering in the canyons late at night. I didn't know until it was to late. You have the chance to replace it now before you lose the belt.
