Misfire on 4
Old Jan 23, 2010 | 05:58 PM
RysaMess's Avatar
RysaMess
Default Misfire on 4
I've got a 99 Dakota 5.2 and here's the problem, I've got a miss, wife tells me the check engine light is on yesterday. Get a code reader and it says misfire in 6&4, compression test all cylinders, all around 85 - 100 psi, change the plugs for cylinders 1-8 , still now reading only misfire 4, change the wire for 4, still reading misfire 4, change the injector from cylinder 2 -4 and vice versa, thinking if the injector is buggered, then the misfire would move from 4 to 2. Then go for a drive, misfire 4. Grrrr, anyone else any suggestions?
Old Jan 23, 2010 | 08:32 PM
Independentfool's Avatar
Independentfool
check for spark on #4.
Old Jan 23, 2010 | 11:35 PM
NYsteve's Avatar
NYsteve
i agree. i'd say to change the distributor cap and rotor. if not, i had a similar problem with a car i had a while ago. changed all the wires and it went away.
Old Jan 27, 2010 | 02:48 AM
RysaMess's Avatar
RysaMess
Problem fixed....
Old Jan 27, 2010 | 06:47 PM
NYsteve's Avatar
NYsteve
Originally Posted by RysaMess
Problem fixed....
so what was it?
Old Jan 30, 2010 | 02:07 AM
RysaMess's Avatar
RysaMess
It turns out that a hold down screw on the distributor broke and caused the distrubutor to tilt. The rotor caught the #3 cylinder point and broke it, so when it fired on 3 it sent sparks to all other cylinders, causing an electrical storm of sorts
