biggest tire on stock rim
Old Jan 23, 2010 | 08:53 PM
ZAKMAN's Avatar
ZAKMAN
Default biggest tire on stock rim
wats the biggest tires that can fit on a 98 dodge dakota sport stock rim?
Old Jan 23, 2010 | 08:55 PM
thunder98110's Avatar
thunder98110
search the threads, the answer is there. or maybe the FAQ section. it gets asked alot here.
Old Jan 24, 2010 | 01:34 AM
f0x672's Avatar
f0x672
youre going to only be able to tuck up to 31's in that wheel well on the 15" rim, on the 16" whatever that metric size translates to 31", do a body lift and you can slam 33's in with some rubbing. crank up your torsion bars if you have 4wd
Old Jan 24, 2010 | 11:26 AM
ZAKMAN's Avatar
ZAKMAN
im doing a 3 inch lift so i could fit 33s on the stock rim?
Old Jan 25, 2010 | 10:55 AM
fourpointseven's Avatar
fourpointseven
yup, you will have to do some light trimming of the inner plastics and maybe the bumper a tad. also, where the body line meets right behind the tire, i'd cut it on an angle so when you do absorb bumps while your turning you wont slice the outside of your nice new tire. Just a thought for you. a grinder + cutting disc will solve your rub
Old Jan 26, 2010 | 11:07 AM
RysaMess's Avatar
RysaMess
I run 32x11.5r15 on my 99 Dakota, stock, torsion bars are cranked, they only rub if I crank way over and am jacked in a ditch turning around, other then that they are all good.
