Dodge durango dakota 4.7 engine part out 98 99 00 01 02 03 1998 1999 2000 2001 2002
Old Feb 2, 2010 | 09:23 PM
norcalaudi's Avatar
norcalaudi
Default Dodge durango dakota 4.7 engine part out 98 99 00 01 02 03 1998 1999 2000 2001 2002
DODGE DURANGO DAKOTA 4.7 ENGINE PART OUT 98 99 00 01 02 03 1998 1999 2000 2001 2002 2003
I HAVE A 2000 DODGE DURANGO 4.7 WITH VIN "J" THAT THE RIGHT HEAD WENT OUT SO IM PARTING OUT THE ENGINE AND THE ENGINE BAY. I AM NOT PARTING ANYTHING OTHER THE THE ENGINE BAY SO PLEASE DONT ASK FOR SEATS OR AXLES OR DOORS, JUST ENGINE STUFF. IF YOU ARE INTERESTED, PLEASE SEND AN EMAIL TO norcalaudi@hotmail.com I HAVE PICTURES OF EVERYTHING SO SEND ME A EMAIL AND ILL SEND YOU PICS. EVERYTHING WORKS. CAR ONLY HAD ABOUT 80K MILES ON IT. I LIVE IN NAPA, CA BUT I AM WILLING TO SHIP OUT WHEREVER YOU ARE. I HAVE A PAYPAL ACCOUNT OR YOU CAN SEND ME A CHECK OR MONEY ORDER WHATEVER YOU PREFER OR COME PICK IT UP. THANKS. BELOW IS EVERYTHING I HAVE:
COMPUTER MODULE R6029124AC (2003 DURANGO)
FEUL INJECTORS
ELECTRONIC COILS
STARTER
ABS MODULE
BRAKE MASTER CYLINDER
VACUME MODULE
WINSHIELD WASHER MOTOR
COMPLETE INTAKE MANIFOLD
WATER PUMP
SERPENTINE BELT (10K MILES)
SERPENTINE TENSIONER AND PULLYS
A/C COMPRESSOR WITH RESOVIOR AND PIPES
POWER STEERING PUMP WITH PIPES
ALTERNATOR
RADIATOR FLUID AND WINDSHIELD WASHER FLUID RESOVOIR WITH MOTORS AND PIPES
CRANKSHAFT (PERFECT CONDITION, NO SPUN BEARINGS)
LEFT CYLINDER HEAD (CLEAN AND IN GOOD CONDITION)
ROCKERS (ONLY HAVE 6 LEFT FROM OTHER HEAD)
LIFTERS
CAMSHAFT CAPS
OIL PUMP
TIMING CHAIN COMPLETE KIT (REPLACE THE GUIDES AND YOU HAVE DAMN NEAR A NEW SET
CYLINDER HEAD BOLTS (2 SETS)
PISTONS AND RODS IN GOOD SHAPE, JUST BUY NEW RINGS (5 REMAINING)
EXHAUST MANIFOLD (BOTH SIDES)
OIL PAN AND OIL PUMP SUCTION PIPE
CAMSHAFT COVERS (BOTH SIDES)
OIL DIP STICK
OIL FILLER RESOVOIR
FAN
FLYWHEEL AND SPACER
ENGINE MOUNTS (2003 DURANGO)
CRANKSHAFT PULLY WITH BOLT
TIMING COVER FRONT ENGINE MOUNT (ENTIRE METAL PIECE THAT WATER PUMP, WATER PIPES, ALTERNATOR, POWER STEER PUMP AND A/C COMPRESSOR MOUNT TO.
AND FINALLY I HAVE THE BLOCK THAT NEEDS TO BE TAKEN TO A MACHINE SHOP. CYLINDER 8 HAS A CRACK BUT IVE TALKED TO A REPAIR SHOP AND THEY SAID IT RUNS ABOUT $500 TO BORE IT AND PUT A SLEEVE IN IT.
AGAIN I HAVE PICTURES OF EVERYTHING SO PLEASE EMAIL norcalaudi@hotmail.com or call 707-363-0520 FOR FURTHER QUESTIONS OR PICTURES. THANKS
Old Feb 3, 2010 | 05:30 PM
Crazy4x4RT's Avatar
Crazy4x4RT
You can try www.ebay.com or www.craigslist.org Did you post it in the classifieds on this site.
Old Feb 3, 2010 | 09:17 PM
debismustang68's Avatar
debismustang68
Can anyone tell me what site i can find that shows if 2000 quad cab parts fit 2001 quad cab? We have two truck, that are both kinda wrecked and want to make one truck out of them....any help would be appreciated.
Old Feb 3, 2010 | 09:21 PM
tamcnally's Avatar
tamcnally
From: Salisbury, Vermont (home) - Lima, Ohio (school)
they should interchange.. there was a dash change in these daks somewhere in the 00's not sure when that would probably be your only problem, if it looks like it will fit then it probably will.
