front shocks on 2003 quad cab dakota
Old Feb 6, 2010 | 06:31 PM
Baby Blue's Avatar
Baby Blue
Default front shocks on 2003 quad cab dakota
Got some clunking going on in the front end and pretty sure is the front strut shocks. if there anyway of replacing them without compressing the spring?
thanks, Mark.
Old Feb 6, 2010 | 10:05 PM
Josh Abels's Avatar
Josh Abels
Put a Jack under the control arm when uve got the truck on a jackstand that's how we did it on my buddy's ram
Old Feb 6, 2010 | 10:07 PM
Independentfool's Avatar
Independentfool
are you sure its not balljoints?
jack the truck up, grab the tire at 6 and 12 and rock it. If theres play, its the BJs.
Old Feb 7, 2010 | 03:22 PM
Baby Blue's Avatar
Baby Blue
yep.. lower ball joint. thanks for the info.
anyone tips on changing out the lower ball joints... rivited in .
thanks, Mark.
Old Feb 7, 2010 | 03:31 PM
01SilverCC's Avatar
01SilverCC
thanks, Mark.
Yeah, check this out, the actual post is on the next page:
https://dodgeforum.com/forum/2nd-gen...to-w-pics.html
Jimmy
Old Feb 7, 2010 | 07:35 PM
Baby Blue's Avatar
Baby Blue
Default Lower ball joint replacement
Changed out the lower ball joint and thanks for the info here is went surprising well. Rivits actually drilled out quiet easily.. pretty soft steel. Use a little wd-40 or something to keep bits cool and it will go nicely for you. I used 4" cut off wheel first and then ground the head off. Drilled a 11/32" then 1/4" then another just under 3/8".
thanks again for all the tips here.
Mark.
