heater question
Old Feb 11, 2010 | 11:47 AM
11/24/07's Avatar
11/24/07
Default heater question
on a 2000 dakota which heat settings would use recirculated air? shutting off outside air.
vent? floor? floor/defrost? or defrost?
And does anyone know where the recirculating door and the blend doors are on this model?
please specify!
Old Feb 11, 2010 | 11:54 AM
Tizzy1's Avatar
Tizzy1
The recirculation mode is available in the panel and bilevel modes only. The door is on the passenger side of the vehicle and can be viewed from the floor area. It is controlled by a vacumn actuator with 2 green vacumn lines going to it.
Old Feb 11, 2010 | 12:34 PM
11/24/07's Avatar
11/24/07
When you say panel and bilevel, i dont know exctly what your referring to.is panel=dash vent and bilevel=dash vent and floor vent?
Then when it is Recirculating air, is the vaccum supposed to be sucking or not?
Old Feb 11, 2010 | 01:29 PM
Tizzy1's Avatar
Tizzy1
Panel = dash vent, bilevel = dash/floor. There are 2 vacumn lines to the actuator, it sucks on one to pull it one way and sucks on the other to pull it the other way.
Old Feb 15, 2010 | 02:51 PM
11/24/07's Avatar
11/24/07
thank you for your help!
