Exterior Fan Noise
Old Feb 20, 2010 | 07:46 PM
SpencerS's Avatar
SpencerS
Default Exterior Fan Noise
Hello,
I recently purchased a 2000 dodge dakota 4.7l v8, and ever since i got it the exterior fan noise completely overpowers the sound of the truck. I had my buddy sit in the truck and rev it for me, all i could here was that damn fan. I cant even here the nice magnaflow i just put on it.
Is this normal for the 4.7 v8s in dakotas?
is there a certain fan i can buy to reduce the amount of noise it emits?
thanks for your time.
Old Feb 21, 2010 | 12:06 AM
dodgeramguy85's Avatar
dodgeramguy85
You need a new fan clutch. When mine is cold it sounds like a tank going down the road then about 200-300 yards down the road it is off and you can hear it another option is to loose the fan and install a electric fan
Old Feb 21, 2010 | 04:33 AM
macx's Avatar
macx
After having a good sized electric fan for a couple years now, I'm a firm believer.
When I installed mine, I used a Lincoln Mark VIII fan as it was about the biggest air mover available at the time without going brand name aftermarket and spending a huge bunch of $. Got it good used for under $100 with a little shopping online, on parts searches. New oem brand motors are available most any parts store, too.
Being it draws pretty good, I used a relay but also a soft start variable speed Flex A Lite controller which works like an absolute charm.
I understand the hot setup now for hot street is the Chev (forgive please!)
HHR electric fan available new at Rock Auto for quite reasonable.
Here's my write-up. (Never mind that it's on a Durango -)
http://www.mediafire.com/?sharekey=1...d6a8b02d5bbda4
Old Feb 21, 2010 | 09:46 PM
SpencerS's Avatar
SpencerS
so i probably would want to buy a electric fan setup if the sound of the fan completely overpowers the sound of the truck no matter if its cold or warmed up already?
it only roars like a tank when it jumps into the passing gear while driving. But im not talking about the roaring sound, just the static sound of the fan blowing.
Old Feb 21, 2010 | 09:52 PM
MadisonDakota's Avatar
MadisonDakota
You need a new fan clutch. Yours is seized up making it spin full speed no matter the engine temp.
Old Feb 21, 2010 | 10:04 PM
SpencerS's Avatar
SpencerS
oh, ok. Forgive my technical appurtenance, I will replace the fan clutch and update from there. Thank you for your time and advice.
