Blowing wiper fuses
Old Feb 21, 2010 | 01:47 PM
USMC Dodge's Avatar
USMC Dodge
Default Blowing wiper fuses
So it just started snowing here in Kansas and I need some help, I can't drive my truck because the wiper fuses keep blowing. My wipers just quit after driving for a minute, so I changed out the fuse. But when I turn on the key with the wiper switch off the new fuse blows. I changed out the fuse again and it blows again. What can be causing this?
Old Feb 21, 2010 | 01:59 PM
thunder98110's Avatar
thunder98110
not sure, try a higher fuse or maybe its a ground.
Old Feb 21, 2010 | 05:15 PM
tamcnally's Avatar
tamcnally
From: Salisbury, Vermont (home) - Lima, Ohio (school)
Do not replace it with a bigger fuse. That will only cause more problems. If it keeps blowing fuses then what you have is a short to ground. Check the wiring for wires touching or a power wire touching straight to a piece of metal. If you don't see anything the wiper motor itself could be internally shorted.
Old Feb 21, 2010 | 06:04 PM
USMC Dodge's Avatar
USMC Dodge
So I took off the cowl and blew out the connection point at the motor and that somehow seemed to fix. Thanks for the advise though
