Hard delayed reverse
Old Feb 24, 2010 | 10:09 PM
ngaarcher's Avatar
ngaarcher
Default Hard delayed reverse
Hi all new to the forum and need some help. I have a 97 4WD Dakota with a 5.2 and a 44RE transmission. When I first put the truck into reverse it does not move. I can hear and feel it go into reverse but it just sits there like it is in neutral. After several minutes it will finally start to move, usually after giving a little gas and with a loud clunk. If I rev it up a little it will not take as long but it goes in really hard. After I have driven it around and everything has warmed up it will go into reverse almost immediately although sometimes it will delay a second or two and go in with a quieter clunk. I have drained the fluid, put in a new filter, adjusted the rear bands and replaced the output speed sensor. I don't know much about transmissions and would greatly appreciate any advice that you can give me.
Old Feb 25, 2010 | 08:56 AM
rtspeedemon's Avatar
rtspeedemon
Sounds like a front pump issue. When its cold the fluid is thicker and it sounds like it is having trouble pushing the fluid.
Old Feb 25, 2010 | 10:30 AM
ngaarcher's Avatar
ngaarcher
This morning it was colder than it has been the past week and it would not go into reverse at all. I had to push it out of the driveway. On the way to work it started slipping in drive. when I got to work, put it in reverse and it went in smooth with no problems.
Old Feb 25, 2010 | 02:22 PM
dodgeramguy85's Avatar
dodgeramguy85
Mine used to always go into reverse but it did clunk in after sitting a day or so. If it has been sitting awhile before I leave Ill shift it into N and keep it in for about 10 sec and that seems to work and keeps it from clunking in.
Old Feb 26, 2010 | 12:08 PM
chickenlights's Avatar
chickenlights
definatly sounds like a pump issue. since reverse requires a higher line pressure. damn dodge automatics.
Old Feb 27, 2010 | 10:28 AM
deranged's Avatar
deranged
Years ago I had parked a Dodge with a 727 torqueflite for an extended period of time. After getting it back on the road it had this exact problem. A buddy of mine who had extensive knowledge of transmissions told me that it was a governor sticking because of varnish. He told me to wait for it to finally engage reverse and when it did to floor it for half a block (in reverse), then drive forward and repeat 3 or 4 times. The problem went away instantly afterwards. Any time after that when it occurred I just followed the same procedure and it worked every time.
Worth a try. Aren't these just a derivative of the old 727?
Old Feb 28, 2010 | 08:33 PM
ngaarcher's Avatar
ngaarcher
The majority of folks on here and one guy at work have said it was the pump. I have also noticed that on a couple of occasions during a hard left turn it has acted strange, sliping or something. I've read that is an indication of fluid being low , but I have triple checked and the fluid is right on the money. Would the pump also be causing this?
