Check Code P1784
2000 Dakota Auto, 2X4, 4.7L V8
I have never had any shifting problems from my dakota... This morning my truck's transmission slipped real hard only one time, and immediately after, my check enginge light came on. I dont think it shifted into overdrive after that because the RPMs ran higher than usual. Went to Autozone to get the code read and they came up with: P1784. On an unrelated subject, I replaced the upper radiator hose and thermostat last night. Dont think this would have anything to do with what happened this morning.
Does anyone know this code?
the list i got is'nt that long.
(maybe) P1764 (M) Governor Pressure Sensor Volts Too Low The Governor Pressure Sensor input is below an acceptable voltage level.
i replaced mine for like $100
search the faq from the begining and u should find the lists of cel codes
