Rubber Gromet Squeek
Old Mar 22, 2010 | 11:57 PM
SpencerS's Avatar
SpencerS
Default Rubber Gromet Squeek
hey guys,
When i got my tires changed, i asked the dude to get under there and crank my torsion bars for me. We got em about even and it leveled out the truck. Before hand there was only a slight squeek from around the shocks when going thru pot holes and bumps and stuff, after the crank thesound is pretty apparent now. It doesnt sound like the shocks are squeeking themselves but it sounds like rubber on metal.
When i got under my truck i noticed some rubber gromets where the shocks are mounted. my question is: is there something i could spray on there to lessen the squeek or will i have to jack it up and replace those gromets? or what else could cause the squeek?
thanks for your time!
-spenc
Old Mar 23, 2010 | 12:28 AM
CSCustomCars's Avatar
CSCustomCars
well, you can spray those bushings one at a time and take a drive after each one to pin point which bushing is causing the squeak and then replace that bushing.
Old Mar 23, 2010 | 01:28 AM
alleymad99SLT's Avatar
alleymad99SLT
Hmmmmm...squeaks when going over bumps? Both sides or just one? I sprayed the hell outta the rubber pieces on the suspension with some kind of spray grease when I had such a squeak, and it worked for about 2 days. Then it started squeaking again and got progressively worse. I ignored it, thinking there was no way I was going to coat my truck with lubricant every day or two.
About 1500 miles later, I noticed obvious wear on the inside of my front tires. The squeak was coming from worn out ball joints.
Old Mar 23, 2010 | 12:48 PM
SpencerS's Avatar
SpencerS
ok, will wd-40 work for each individual spray?
Old Mar 23, 2010 | 01:40 PM
CSCustomCars
^^ Yeah that'll be fine.
