99 Dakota ABS code 70 & 71
Old Apr 10, 2010 | 01:16 PM
02bigblue's Avatar
02bigblue
Default 99 Dakota ABS code 70 & 71
code 71 &72 in abs lite is on also brake lite is on any ideas please help do i need a new cab???Thanks
Old Apr 10, 2010 | 06:50 PM
alleymad99SLT's Avatar
alleymad99SLT
Rear speed sensor.
Front ABS sensors.
Are you having any issues with the speedometer? When my rear sensor went out, I lost the speedometer from like 0 to 20 mph plus got the ABS / brake light.
If you wanna test the sensors with an ohm meter, the rear should read 2K ohms and the two front ones should read 1K ohms.
Its one of those three. The non-working one will show open when you hook the ohm meter to it.
They are all pretty cheap, but it might be beneficial to figure out which one is bad before buying three sensors.
