tranny installed but some problems
Old Apr 17, 2010 | 09:22 AM
ZAKMAN's Avatar
ZAKMAN
Default tranny installed but some problems
the tranny is fine but the check engine light is on and at low speeds around 30 mph the truck has a weird vibration but at 60 its gone and when it happens i can put it in neutral and put the clutch in and it keeps doing it so idk
Old Apr 17, 2010 | 01:40 PM
CSCustomCars's Avatar
CSCustomCars
Output shaft - I.E. Tail Shaft? U-Joint could cause that too.
Check the code for the CEL.
Old Apr 17, 2010 | 06:59 PM
ZAKMAN's Avatar
ZAKMAN
how could that cause a vibration?
Old Apr 17, 2010 | 07:54 PM
varsis's Avatar
varsis
yep check the code. Sounds like though you forgot to plug something in when r&r.
Ujoint can cause a large vib.
Old Apr 17, 2010 | 09:30 PM
bpark8824's Avatar
bpark8824
Sorry to be off topic, but varsis, doesn't your sig need to be updated? lol
Old Apr 18, 2010 | 11:19 AM
ZAKMAN's Avatar
ZAKMAN
i had to use a diffrent yoke and a conversion joint to get the tranny in could that cause the driveshaft to be off balance?
