disconnecting power lock wires at ctm
Old Apr 25, 2010 | 01:54 PM
JUnit's Avatar
JUnit
Default disconnecting power lock wires at ctm
I want to cut the wires that give power to my locks as they spasm on and off by themselves and I have no money to get them fixed. Right now I have the top set of wires unplugged from the ctm as this solves the problem when I have to park. I was thinking I could plug the top set back in and just cut the wire controlling the locks. I've researched a little and tried cutting the white/light-green wire but that didn't work. I looked in my manual and it says white/light-green controls the passenger door switch mux and white/dark-green controls the driver door switch mux, however I don't see a white/dark-green wire. Anyways I was wondering if anyone knew the correct wires to cut. I have a 02 2 door dakota.
Old Apr 25, 2010 | 05:55 PM
JUnit's Avatar
JUnit
I got impatient and started cutting wires, turns out the correct ones were two identical green/black wires. Thanks for the incorrect wire color service manual...
