what size tires should i get
Old May 17, 2010 | 03:36 PM
Hinkster15's Avatar
Hinkster15
Default what size tires should i get
Im putting a 3 inch body lift on my truck. What size tires should i get. I dont want any rubbing but i want the biggest tire possible. I have a 2003 dodge dakota sxt. i was thinking 31s
Old May 17, 2010 | 03:55 PM
SpencerS's Avatar
SpencerS
31s look silly. 33x10.5, 33x12.5, 275/70, 275/75 are all around 33 inchs. the diff is the wheel size they come in.
Old May 17, 2010 | 03:57 PM
Hinkster15's Avatar
Hinkster15
but will they rub.
Old May 17, 2010 | 04:48 PM
dodgeramguy85's Avatar
dodgeramguy85
Just a lil fyi im running 31's on stock suspension,no body lift and no cranked tb so I would prob do 33's
Old May 17, 2010 | 05:13 PM
00dakSport's Avatar
00dakSport
yea i also have 31"s on my stock height truck.
and theres still alot of room. i think i've even seen stock trucks
w/ 33"s on them but they would def rub. but w/ your lifted
truck you should be fine. i found these in a durango section might help ya.
https://dodgeforum.com/forum/1st-gen...pressions.html
Old May 17, 2010 | 10:06 PM
SpencerS's Avatar
SpencerS
with the lift there is plenty of room for 33s, hell ive seen some guys put 35s on with a 3inch body.
also if your truck is 4x4 you can crank the torsion bars(or torsion keys) and add blocks in the back for another 1 or 2 inches.
Old May 19, 2010 | 01:29 AM
Chenz30's Avatar
Chenz30
New Member
I have 33"s on my stock height 03 3.9L. They rub a little and make some noise when I turn corners but not enough to notice a decrease in the turning radius. Im looking to lift my truck a few inches and I would def suggest going with 33" tires. 31"s just look too small with a lift.
