Best way to remove a 5.2/5.9 from second gen truck?
Old May 24, 2010 | 10:55 AM
dbilik's Avatar
dbilik
Default Best way to remove a 5.2/5.9 from second gen truck?
I am in the process of removing a 5.2L from a second generation body. I have a first gen also and it seems like I have a lot more room behind the firewall to unbolt the trans to engine bolts. It wasn't even a huge deal on the 4.7L engine. Because of the intake I can't easily reach these bolts.
So, what is the easiest way? Pull the engine and trans out at the same time? Drop the drive shaft and trans to change the angle?
Old May 25, 2010 | 01:44 AM
Jdb107's Avatar
Jdb107
From the threads i've read, it seems most people pull the engine out with the tranny at the same time. although i could be mistaken
