engine swap info
Old Jun 1, 2010 | 12:43 AM
doug1978's Avatar
doug1978
Default engine swap info
so i have been reading and havent come across anything about the oil pan iam going to swap my 5.2 out of my 98 dakota for a 5.9 from a 95 ram so do i have to buy a oil pan for a dakota r/t or will the oil pan off the ram work aslo do i need anything else or will everything else work and will the 5.9 from the ram have the same power as a org dakota r/t
Old Jun 1, 2010 | 12:46 AM
crateampsrock's Avatar
crateampsrock
should be identical
Old Jun 5, 2010 | 05:50 PM
BlueHemi's Avatar
BlueHemi
i just swapped a 5.9 from a 2000 Ram into my uncle's 98 Dakota and used the oil pan from his 5.2 because there was a little difference in the shape and I didn't want to take any chances on the 5.9 pan rubbing on anything.
