Front diff locker.
Old Jun 6, 2010 | 09:09 PM
fourpointseven's Avatar
fourpointseven
Default Front diff locker.
thinking about putting a Front diff' locker in my dak. where can i find the frontlocking guts to fit in my diff? If you need to know it's a 04
Old Jun 6, 2010 | 09:59 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I don't believe there are any. Try www.summitracing.com or http://www.ringpinion.com/Makes.aspx?SearchMode=Make
But a locker in the front is not a great Idea unless it is a selectable unit and you would only want it on when going in a straight line, No turns!
Get one for the rear. That will increase your traction, nothing will compare.
Old Jun 7, 2010 | 12:55 AM
fourpointseven
Crazy4x4rt, Where Can i find this kit for the Rear end then? would absoultly like to make it a positive rear end! What ring and pinion set-up would you use for a offroad truck?? what size, and where can I locate a kit
Old Jun 7, 2010 | 01:17 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Try the same links I posted in the first post! As for what ring and pinion you can keep your stock or go with a lower ratio for tq. It will help if you run larger tires too. Again for R+P sets look at the same links.
Old Jun 7, 2010 | 01:55 AM
fourpointseven
PMd ya! lets talk differentals.
