Window Tinting
Old Jun 22, 2010 | 11:13 PM
NyghtProwler's Avatar
NyghtProwler
use some wrapping paper and make a template.....then cut 1/4 in over on each side.....use plenty of soapy water and take your time....do it where you'll have no wind......
Old Jun 22, 2010 | 11:14 PM
dodgeramguy85's Avatar
dodgeramguy85
Originally Posted by Hinkster15
how about cuting them out by hand like outing it up to the window and using a razor blade. because as of now i have no way of being able to get a shipment. Unless they sell the pre cut ones at autozone or orielys
Well you can but pre cut is 10x better you dont have all the extra tint getting in your way and messing you up and plus its hard to get a straight cut that wont peal later on down the road. When I did mine I didnt take mine right flush with the top of the window I left it a little bit down and couple days later I took clear fingernail polish and took it around the edge of the window to make sure that after putting the window up and down a couple of times it wouldnt peal at all and it worked still doing great.
Old Jun 22, 2010 | 11:21 PM
Hinkster15's Avatar
Hinkster15
k im gonna try and attempt it tommarow i will let you know how it goes.
Old Jun 22, 2010 | 11:57 PM
thunder98110's Avatar
thunder98110
like mentioned earlier use a crap ton of soapy solution, and use a credit card wrapped with a towel and press out all of the bubbles for like 3 minutes. then let it bake in the sun for a few days.
Old Jun 23, 2010 | 01:18 AM
Independentfool's Avatar
Independentfool
you will also want to check your state law on how dark you can go. Dont want to get lame tint tickets.
Old Jun 23, 2010 | 10:21 AM
dodgeramguy85
I recommend not using a credit card they seem not to glide as smooth as a actually small squeegee like they only need to be about 1/4'' thick about 3 inch long made or rubber then with the edge cut at a 45 angle. Make sure you clean your windows really good before you start and make sure there is no little hairs or fibers from the towel left over. Then make sure you dont skimp on the water/soap solution and also remember to spray the window and the tint when its good and covered lay the tint on then you have about a min or 2 to get it where you want it. Its best to have some one to help you you can do it by yourself but its always much easier when a friend can help you out. Take the squeegee and work your way out from the middle working in all directions evenly and going over the same spot more than once remember not to work to far ahead of yourself just take your time and work on all the air bubbles
Old Jun 23, 2010 | 05:42 PM
JBs DAK's Avatar
JBs DAK
My bother does it for a living,..
One trick is to always clean your windows
the best you can then, with them dry, take a NEW
straight edge razor and lightly scrape the entire window
as if you were shaving it. Then wash it again with a lint free cloth.
This is your 1st step before ever attempting to apply the tint...
It works. Get a bubble you just can't get out while applying the tint?
You shouldn't but, if you do, use a pin to pop it and continue. Good-luck.
Old Jun 23, 2010 | 08:15 PM
00dakSport's Avatar
00dakSport
Originally Posted by dodgeramguy85
Thanks and yeah I only use windex
i don't think thats good. windex and alot of other cleaners use ammonia.
the guy at the shop said not to use it, instead use tint safe spray or soapywater. just trying to help u out.
Old Jun 23, 2010 | 08:17 PM
fourpointseven's Avatar
fourpointseven
tint Is easy... after the first 2 rolls i wasted. This is how i figured out How to do it yourself 10 minutes a window.
Before you do anything, WASH YOUR WINDOWS!! (then spray your window your going to tint with soapy water)
Step 1 : buy some bristol board And make a template of your window.
Step 2 : Cut out the tint for both sides
Step 3 : Take a spray bottle with soapy water and peel the plastic off the tint, . Get A buddy to Spray the sticky part of the tint with the soapy water as you peel it, ALL of it. <--I can't stress this enough, if you dont the tint will stick to eachother and it's ruined. spray as you peal
Step 4 : Apply it to the window and push the bubbles out with a bank card or antyhing
Step 5 : get an olphan blade and cut away any access tint and peal it off.
Step 6 : Let the sun dry up the water and it will be stuck on, Easy!
Done.
thunder98110
yea i heard Johnson and Johnson baby shampoo works the best
