2003 dakota kills intermitantly
Old Jun 24, 2010 | 07:25 PM
allenorchard's Avatar
allenorchard
Default 2003 dakota kills intermitantly
i need help!!!! when drive and some times from a dead stop my 2003 dakota with the 4.7L completly kills the imediatly starts running again. when i pull over it will idle but when you push the gas again it kills again. when this happens the tach and the speedo fall to zero and the engine light flashes but all other gauges stay at operating level. every once and a while it will throw a P0068 code. i've replaced the throttle position sensor and the crank sensor. what could this be???? please help
Old Jun 28, 2010 | 10:38 AM
allenorchard
Is there possably a relay that could be bad for the computor. Because every thing else in the truck stays on. It's just killing the engine and the gauges for the dash, all the dash lights and the gauge lights stay on when this happens. Or could it be the computor it self screwing up. The truck is throwing no codes.
Old Aug 2, 2010 | 03:28 AM
fireahi's Avatar
fireahi
Default Check your asd relay
Check your asd relay and ground and power and fuses to make sure its ok also check your battery and ground and post wires for loose or corriode connections.
fireahi
