tmr mod
Old Jun 27, 2010 | 11:42 PM
thunder98110's Avatar
thunder98110
Talking tmr mod
so i was cruizing around on dakota-durango forum and found the tmr mod. basiccly makes the tranny shift harder for 4.7L who have a 3plug pcm. i guess you cut the yellow wire with the green tracer #10 going to the tcm. just wondering if anyone on here has done it before i go cutting wires?
Old Jun 28, 2010 | 12:41 AM
thunder98110
nevermind, i just need to get a pair of needle nose pliers tomorrow and pull the wire instead of cutting it. ill post back up tomorrow.
apparently you can chip the tires in second!
Old Jun 28, 2010 | 10:43 AM
thunder98110
damnit!!!!! either the battery died or i really effed something up. no power anywhere!
heard a pop when i tried to crank it the first time......fuses look fine, maybe some starter relay?
Old Jun 28, 2010 | 12:57 PM
cowboy63645's Avatar
cowboy63645
sounds like a relay if there isnt any power anywhere. Ormaybe the main fuse for the fuse block that went.
Old Jun 28, 2010 | 01:21 PM
bpark8824's Avatar
bpark8824
Haha that's why I don't f*ck with electrically stuff lol. I will always mess stuff up like that if I started pulling wires.
And I'm no expert when it comes to wiring, but I would start by re connecting the wire you pulled...
