1999 dodge dakota suddenly dies
Old Jun 28, 2010 | 03:44 AM
tarrin8's Avatar
tarrin8
Default 1999 dodge dakota suddenly dies
so i have a 1999 dodge dakota 5.2L 5spd 4x4 , and the last 2 days the truck would randomly die, but it'll start back up again in 5-10 mins mostly ( 1 time it took an hour) but there usually is no warning , 1 time it did chug a bit and i put the clutch in and the rpms went back up so i drove along and it chugs a bit more then died , it will do it when the truck is warm or cold , usually when im driving but it has died after it sat for 2 hours (it sat for 2 hours and i went to start it to go home and it started for 2 secs then died , took 15 mins to stat again) then i drove 1 or 2 km down the road and it died for about an hour.
i dont know what it could be but i have been reading other forums that lead me to thinking its the PCM,crankshaft sensor or what else??
its just wierd that it will die for 5 mins then start back up and run perfectly fine and die without warning again....
but heres the thing when i first got the truck (march 18th 2010) it died 2 times on the same day and i called the dealership the next morning and they checked it out and found nothing , and now 3 1/2 months later it does the same thing again but alot more and the 30day warranty the truck had is up! so i need to find out what this is because i need the truck for work.
also if it is the PCM does it need to be programed before i put it in or do i just order it and plug it in ?
Old Jun 28, 2010 | 04:58 PM
corpusfisherman's Avatar
corpusfisherman
is it a temperature dependent intermittent problem? as in, does it run fine until it gets close to operating temperature, and then die? then start and run fine after it gets up a little warmer?
Old Jun 29, 2010 | 02:32 AM
that_1_guy's Avatar
that_1_guy
i would guess crank shaft position sensor. i had a jeep that did the same thing and cps is what it was
Old Jun 29, 2010 | 02:57 AM
tarrin8's Avatar
tarrin8
usually it died when it was warmed up but it did die cold too, when it did die cold it would die 2-10 seconds after it started, 5 mins or so later the truck would start, but mostly once warmed up the truck would die.
havent drove the truck in 2 days but have started it and let it run 5-10 mins and the truck ran good
well today im gonna have a good look at it check wires and connections, then go for a drive see what happens
