Did a little cleaning...
Old Jul 1, 2010 | 01:46 PM
cowboy63645's Avatar
cowboy63645
Default Did a little cleaning...
Well, since I went through the other day and did a complete tune up on the truck, including plugs, wires, TPS, air filter, changed front and rear diff fluid, I thought it was about time to clean the IAC and the throttle body. The pictures I have taken are after I got it off the truck and taken apart, and are somewhat clean. wow, after seeing what it looked like before, it should run a little smoother!
And this is what the intake looks like! Since I might have to take it off anyway to get to the top bolts for the bellhousing to take the transmission down, I might just clean it up a little as well.
Old Jul 1, 2010 | 03:13 PM
corpusfisherman's Avatar
corpusfisherman
thanks for the pics! so, only four bolts holding that on? seems easy enough, maybe I'll take mine off and clean it up this evening.....still having a problemo I can't get my finger on (see the "this will stump you thread")
corpus dood...
Old Jul 1, 2010 | 03:17 PM
cowboy63645
Yeap, just 4 bolts holding the TB on, but there are 3 small bolts (8mm) holding the throttle linkage bracket on, that needs to come off in order to remove the TB. Fairly straight forward process. I used a can of carb and choke cleaner, an old tooth brush and a few shop towels, and good as new!
