2001 Dakota Problem
Old Aug 18, 2010 | 02:08 PM
dakota19762's Avatar
dakota19762
Originally Posted by magnethead
I'd say replace them before you hurt the motor.
Ditto!!!
I ordered mine here, had them installed for $100. Fit was good and no problems.
http://www.autopartswarehouse.com/se...T20373&submit=
Old Aug 20, 2010 | 12:22 AM
20dakota01's Avatar
20dakota01
I checked the pressure between the the first 02 sensors and the engine and there was right at 1lbs of pressure. The converter hasnt gotten red hot again since the first time. I check it about everytime I shut it off. Lately it has been around 105 degrees with a heat index of 120 out and it did not run good at all when the engine warmed up. Today it was 85 degrees out and it ran like new all day, did not have a problem.....I'm stumped.
Thanks
Old Aug 20, 2010 | 07:15 PM
dakota19762
I know we're not "supposed" to get vapor lock, but since we have this 10% ethanol gas on really hot days I would swear that's what I have. My truck kicks and bucks on a scorcher. Then runs like a champ at night or cooler days. I get the misfire codes on the hot days too, this winter I'll look to see if I get them then also.
Old Aug 20, 2010 | 11:14 PM
20dakota01's Avatar
20dakota01
I was running E10 when this all started. It was running really bad. I stopped using it and it did help for a while a few weeks. Might just have to put up with it I guess....
