4.7 engine swap??
Old Jul 29, 2010 | 01:51 PM
scatpackmopar's Avatar
scatpackmopar
Default 4.7 engine swap??
I found a 2001 Dakota w/ a 4.7 but the engine is no longer with the truck. I have a 1981 5.2L [318cu.in.] Has anyone ever heard of this engine swap before? A 318 for the 4.7? I would most likely have to remove a lot of the enigne electronics and go with an older fashion electronic ingnition. Or how expensive is getting a new [or used] 4.7 and what kinda price is that going to run?
Old Jul 29, 2010 | 11:35 PM
dbilik's Avatar
dbilik
Don't try to swap a 318 for a 4.7, it will be a headache for you I think. You can look around for a used 4.7, I have gotten 2 now for around $1000 each, so they are out there. If it is a 32 tooth engine you can always buy a new tone ring for it and make it work with the 2001.
Old Jul 30, 2010 | 07:14 AM
McNasy's Avatar
McNasy
just another thought for you, here in wisconsin the emission testing makes it impossible to pass if you put an older engine in a newer vehicle. not sure where you live or your emissin laws.
