Dodge Dokota-2001 Air control switch for heat and Air will not actuate floor vents
Old Aug 2, 2010 | 11:43 PM
mello000's Avatar
mello000
Default Dodge Dokota-2001 Air control switch for heat and Air will not actuate floor vents
HVAC air control switch on my 2001 Dodge Dakota
DOES change air flow from defrost to mid level flow
Problem---- when I turn the HVAC switch to floor position
it will not re direct air flow floor actuators must not be engaging
Air continues to flow but not at floor
Can Anyone help me with this problem
Richard
Old Aug 5, 2010 | 05:56 PM
fireahi's Avatar
fireahi
Default no air to floor
I have a bigger promblem then you mines doesn't flow out in the rec mode for in cab air only outside and hot is cold and cold is hot you figure this one out on expert told me you have to go to dealer and get drb 3 to to relearn the door programs to make it work properly?
Well i can't find any thing in the manual or internet about this but I think we are on the same tracks.
If you find anything out email me back or repost if any one else has a fix email or post please.
fireahi- Wyatt
Old Aug 5, 2010 | 11:01 PM
mello000's Avatar
mello000
Default thank you
Appreciate you taking time
If I do find out anything I will both post and mail you
Sincerely
Richard
Old Aug 6, 2010 | 06:28 AM
McNasy's Avatar
McNasy
mine is stuck on defrost. i was told that the "door" is broke and wont redirect the air flow. a new heater box is the fix for that. he said its a common problem on rams and on daks as well.
Old Aug 6, 2010 | 10:34 PM
mello000's Avatar
mello000
Thank you for your reply about the heater box
I had an astro van and all air flow doors -defrost-mid and floor were
vacuum controlled
If only the defrost worked in my astro defrost was the default position for having no vacume.
I had this problem that sounds like your problem and found main vacuum line broken -I replaced broken vacuum line and then all air flow positions mid ,floor and defrost worked.
On my Dakoto both mid and defrost air flow work so I assumed not a vacuum problem
Having said that I am not sure if vacuum controls actuators on air flow doors in Dakota
One of reasons I posted my problem.
I hope this post helps us both
Sincerely
Richard
Dakota is a recent purchase
Old Aug 11, 2010 | 03:34 PM
allbroncos's Avatar
allbroncos
Check this out, I hope it helps.
https://dodgeforum.com/forum/2nd-gen...d-defrost.html
