Dakota a/c problem
Old Aug 11, 2010 | 04:15 PM
gsmith223's Avatar
gsmith223
Default Dakota a/c problem
the other day my a/c started blowing warm so i recharged it. it only held for a day. I ran a dye /stop leak threw the system it slowed the leak but now i can smell what i think is freon blowing in.. the ac seems to be condensating more than usual also. there was no dye present that indicated a leak..it a 2000 3.9 thanks
any ideas?
Old Aug 14, 2010 | 11:49 AM
Crazy4x4RT's Avatar
Crazy4x4RT
The leak could be inside the cab as well. The only way to know for sure is to fix your fist leak. Then charge it up and see if it leaks again. I will move this to the 2nd Generation Dakota sub forum.
Old Aug 15, 2010 | 04:39 PM
gsmith223's Avatar
gsmith223
ok thanks
i think its the same leak its always kinda smelled bad i just cant find the leak. it must be in the cab behind the dash just not sure what part is in the cab and how to get to it???
