Swap Hemi
Old Aug 11, 2010 | 09:06 PM
vbossi's Avatar
vbossi
Default Swap Hemi
Help.. Hi, I am from Brazil and I have a 1999 dakota 3.9 4x2 manual transmission. I want to put a hemi 5.7 in my truck. Hemi will fit with my manual transmission? There is an adjustment for it? will I need a flange? PLease help me. What I have to do? I want my truck with hemi and my oem manual transmission.
Old Aug 11, 2010 | 10:22 PM
dodgeramguy85's Avatar
dodgeramguy85
It kinda depends on what tranny you have now it might be a ax15 or but prob a nv3500. It should work out fine bolting up only thing is a nv3500 is not going to hold up to 400ft.lbs of torque that the hemi makes. Im pretty sure the nv3500 is rated at 300ft.lbs of torque. Your only safe option is the nv4500 it was used with the 5.9 cummins,5.9 v8's and 8.0 v10's so it can handle some abuse
Old Aug 12, 2010 | 08:21 AM
vbossi's Avatar
vbossi
I will use my oem transmission. . I need to know what adjustment should I use? There is a flange for this?
Old Aug 12, 2010 | 11:55 AM
dodgeramguy85
Just warning your tranny might last 10,000 miles if you take it really easy on it
Old Aug 21, 2010 | 02:42 PM
HemiDak-Quad's Avatar
HemiDak-Quad
You should have got the trans. with the Motor. 45-rfe. OR 545 rfe, These are the only automatic, transmissions I would even consider putting behind a new model Hemi.."For a Dakota"...The one you have won't last"IF" It bolts up..You're going from 200 hp MAX to at least 345 hp.on a used Transmission..
Old Sep 17, 2010 | 08:28 PM
HemiDak-Quad
Are you going to do the swap...?
Old Sep 18, 2010 | 06:30 PM
dbilik's Avatar
dbilik
I don't think the NV3500 will hold up to the hemi, the 4500 has a hemi bellhousing available and would be fine, but it is a whole new mod in itself. 95_318SLT is putting an NV4500 in his Dakota right now in the first gen forum. Sorry but you will need a new tranny no matter what you decide to do. The NV3500 has an integral bellhousing which will not mate to a hemi. In addition to that, going from a 3.9 to a hemi is going to be a nightmare from an elecronics stand point. I don't imagine you having a surplus of dodge parts in Brazil.
You would be much better of going to the 5.9L engine, or the 5.2. Even then, the NV3500 should only be used behind the 5.2.
