Power Steering Fluid / Or Brake Fluid Leak ?
Old Aug 14, 2010 | 11:07 AM
ZANGADO's Avatar
ZANGADO
Default Power Steering Fluid / Or Brake Fluid Leak ?
For the last two weeks I have noticed a slight drip smear on the outside of my front left wheel so I wiped it off thinking it was wetness from the inside out of the wheel where is is clearly coming from,so the next time I get out and look and its there again,so I checked the resevoir for Brake fluid and power steering and no loss of fluids? I now see the 4X4 boot is sweating where the tie rod end goes into the back of the wheel and it is also spraying back to the inside of the wheel well with no leaks on the ground overnight so I went and bought some Lucas,used a turkey syringe and took out the old power steering fluid and added the Lucas and it has been two weeks now with no change or issues eccept the small sweating on the outside of the wheel. So I guess I should just deal with it until something breaks like the steering rack? or just ask you guys if it is an easy fix that I am overlooking,one other thing is that I recently had a front end allignment and this problem started showing up after they monkey'd around under there.
