97 5.2 losing power on interstate
Subscribe
Aug 20, 2010 | 09:43 PM
When cruising on the interstate with or without the cruise control on the truck starts loosing power and if i keep the gas pedal in the same position it will start backfiring. If i accelerate it will pick back up but will start loosing power in a few seconds.
It felt as if i was loosing fuel so i changed the fuel pump assymbely and still the same thing. i dont know if it makes a difference but a couple weeks ago i removed the cat and the light stays on for the o2 sensor.
Reply 0
Aug 21, 2010 | 09:17 PM
Any suggestions?
Reply 0
Aug 21, 2010 | 11:54 PM
I had this EXACT issue on my v6 dakota it was that the hoses to the charcoal canister were disconnect and dried out and split
Reply 0
Aug 22, 2010 | 08:30 PM
The charcoal canister hoses sounded very convincing so I checked them today and they are all ok. I also checked the tps and map sensor today and they checked out ok with voltage readings. So if anyone has any more suggestions they will be appreciated.
Reply 0
Aug 22, 2010 | 08:39 PM
How do the plugs look? Might check the rest of the vacuum tubing.
Reply 0
Aug 26, 2010 | 06:12 PM
All the vacuum lines seem to be fine. Now the truck is starting to act up when I get off the interstate as well.
Reply 0
Subscribe
