Can I keep stock size shocks and driveshaft with 2-3" of lift on my 2wd 3.7L?
Old Aug 22, 2010 | 12:06 AM
Rantz's Avatar
Rantz
Question Can I keep stock size shocks and driveshaft with 2-3" of lift on my 2wd 3.7L?
I would like to make sure that I can keep stock size shocks if I am doing 2-3" of suspension lift??
I will be doing this probably with lift coils in the front. Such as found here
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
I believe that these could work for my application. What do you guys think?
For the rear, I'll either be adding a leaf or adding blocks. I just want to make sure that I will be able to utilize the stock size shocks. I also want to make sure that I won't need to mess with the size of my driveshaft.
I understand I'll need to get an alignment, that's no big deal. Will I need to worry about getting longer brake lines? If so, I'm assuming that the parts store will be able to provide me with what I need.
Will I need to worry about backspacing?
As my sig says, '04 3.7L 2wd quad cab
I want a more aggressive look to my truck. I also like the idea of more space to move around there without jacking it up.
Old Aug 22, 2010 | 01:55 AM
magnethead's Avatar
magnethead
the problem with the back, is the spring is under the axle. So lift blocks won't help any. You can do an SOA swap, but that's pretty darn detailed. The better option would be shackles, or to weld up (again, risky, hope you're a damn good welder) custom 1-piece drop hangers.
Old Aug 22, 2010 | 10:03 AM
Rantz's Avatar
Rantz
How would I go about obtaining shackles. After reading through the FAQ it appears that the v8 shackles would lower my truck. Are there shackles that I can buy for my truck?
What if I get spacers to go between the axle and the leaf springs?
So I wouldn't have any issues using my stock size shocks and driveshaft?
Old Aug 22, 2010 | 06:32 PM
Rantz's Avatar
Rantz
I'm going to look into this shackles idea. I don't completely have my head wrapped around how it'll work, but I'm going to give it some thought.
Old Aug 22, 2010 | 06:38 PM
Rantz's Avatar
Rantz
I could do the spring over axle swap and then put the 4x4 shackles. The FAQ says the SOA swap will yield 5" of lift. Then the 4x4 hangers will drop it 2-3". Then if I need to go up an inch, I can add a block. This seems the most cost effective way since the only parts I would need to purchase would be the 4x4 hangers and maybe the 1" block.
My goal is to get 3" of lift. I would then just use the 3" lift coils in the front.
Old Aug 24, 2010 | 12:54 AM
magnethead's Avatar
magnethead
Here's the ones my eyes are on. All you need is 2.5" spring width, doesnt care if they're for a ford or chevy. On a 2wd, because the hangers face down, the shackles say "drop", but are actually lift, because they increase the distance between the hanger and spring.
http://www.summitracing.com/parts/SUM-G904000/
Old Aug 24, 2010 | 11:18 AM
Rantz's Avatar
Rantz
I'm also doing a search on summit for the 3" drop shackles
I'm now looking at some 2" lift coils on ebay possibly
Old Aug 24, 2010 | 09:21 PM
Rantz's Avatar
Rantz
I was advised by the seller of the lift coils that I should get taller shocks to compensate for the lift. How would I know what part #s to look for that would just be a tad bit taller to compensate for the lift and will still be compatible?
Old Sep 18, 2010 | 05:43 PM
Rantz's Avatar
Rantz
Monroe got back to me. The part numbers for shocks that'll fit my truck and be 2" taller are:
front 5938
rear 37140
This whole lifting idea is on hold for now.
Old Sep 18, 2010 | 10:15 PM
midget-farms's Avatar
midget-farms
For 3 inches of lift you wont' need to change the drive shaft unless you do a lot of twisty trail rides. Then the slip yolk (or slip shaft) may pop out at the worst possible moment.
The drive shaft changes length as the suspension travels. So if the rear axel goes into a hole it gets longer when it comes out of the hole the shaft gets shorter. You have a good amount of play. BUt if you lift beyond 3" you don't have enough play to allow for a full cycle of the drive shaft & it will just come apart.
Under 3" & you should be fine.
Since you will be moving the axel around with the blocks/shackles consider a degree wedge to fix the pinion angle. As the lift gets higher the angle of the drive shaft gets worse. This can cause nasty vibrations. The degree shim will correct this. It just slips between the spring & the block you are using.
You will need new shocks for 3". Otherwise the shock is sitting near its bottom instead of in the middle of the cyl. When you hit a bump the shock bottoms out & all the force is transfered to your frame. In other words it will ride like S#!t & you could brake something if you hit bumps too hard.
