Speedo Problems
Old Aug 24, 2010 | 10:08 PM
LESchwartz's Avatar
LESchwartz
Default Speedo Problems
I have a problem with my 99 Dakota 4wd 5.2: My speedometer only works after 25mph and up any thing under 25 it reads 0. The check engine lights is not on, but the ABS and brake lights are on.
Any ideas as to what to check first?
thanks in advance,
Larry
Old Aug 25, 2010 | 07:09 AM
McNasy's Avatar
McNasy
i am thinking that you have a bad speed sensor or abs wheel sensor. if you have 4 wheel abs, the front hubs hold the wheel sensors, then there is 2 more speed sensors. one in the rear diff and one on the trans(i think)
Old Aug 26, 2010 | 11:08 AM
LESchwartz's Avatar
LESchwartz
The vehicle has ABS on the rear only. I've ordered an new speed sensor for the rear differencial, and will post the results.
Larry
Old Oct 20, 2010 | 02:07 PM
norcalmike's Avatar
norcalmike
i just did this today. 30 dollar part at Autozone. they had it in stock. took about 20 minutes to do. Cruise control, speedo and odo didnt work, ABS, Brake and Check Engine light on. all is good now. just replaced the sensor on the rear diff.
Old Oct 21, 2010 | 11:14 AM
LESchwartz's Avatar
LESchwartz
Sorry, but I forgot to post me results . . . replacing the speed sensor fixed the problem for me.
Larry
Old Dec 28, 2010 | 01:02 AM
fldodge4x4's Avatar
fldodge4x4
4x4 is the same? Rear sensor. i cant find it on mine
Old Dec 28, 2010 | 10:45 AM
LESchwartz's Avatar
LESchwartz
Mine is a 4x4 w/rear ABS. The sensor assembly mounts to the top to the rear differential pumpkin. If you have 4-wheel ABS, it might be a different setup.
Old Dec 28, 2010 | 02:08 PM
2000DakotaQuad's Avatar
2000DakotaQuad
any man has a problem if they are trying to wear a speedo
Old Dec 28, 2010 | 10:10 PM
lootownpunx's Avatar
lootownpunx
same problem on my 98 when i had it....a buddy had a v6 reg cab doin the same,ran a scan tool and was the rear speed sensor.
took his advise on my 98 4x4 V8 ..problem fixed
Old Dec 29, 2010 | 08:57 AM
EricBing's Avatar
EricBing
Just a lil note, my 99 and 02 did the same thing, replaced sensor noticed metal shavings on sensor, so i changed out diff lube as well, good time to do it, cause the sensor gets magnetized and picks up shavings when magnet in rear housing gets accumulated with shavings, got to keep diff lube clean.
