Wiring issues
Old Sep 1, 2010 | 12:15 PM
dakota19762's Avatar
dakota19762
Question Wiring issues
Does anyone have a copy of a wiring diagram for an '01 RAM. I swapped out my 3.9 for a 5.9 in my Dakota, But I don't have any gauges. The truck runs, but I'm pretty sure that the wiring is a little different from the RAM to the Dak. Any help is appreciated. I am using the RAM's ECM.
Old Sep 1, 2010 | 01:30 PM
Derek2002's Avatar
Derek2002
Is there a specific diagram you need?I can probably get it from alldata but there is a bunch of them so I cant post them all.
Old Sep 1, 2010 | 02:22 PM
dakota19762
Yes, just the three pin-outs for the engine control harness. Some of the wires on the RAM harness were different from my Dakota. Would like to match them up to get my gauges working, and get rid of the "no bus" on the odometer.
Old Sep 1, 2010 | 02:41 PM
Derek2002's Avatar
Derek2002
Does This Help?Its the ECM Schematic for the ram.
Old Sep 1, 2010 | 02:55 PM
dakota19762
Yes, I can check the wire colors with the old harness. Thank you soooo much!
Old Sep 1, 2010 | 03:00 PM
Derek2002's Avatar
Derek2002
Your Welcome.If you need one for the Dakota let me know.
Old Sep 1, 2010 | 07:06 PM
dakota19762
Thanks again Derek2002, I am trying to find the wires that go to the dashboard, or whatever the computer sends to the dash. I have no gauges at all. I have the Haynes manual for the Dakota, but it looks different from what you have. And there seems to be a lot of connections missing from what you sent for me. I am definitely thankful for what you sent, I just don't know what I need to ask for...
Old Sep 1, 2010 | 08:16 PM
dakota19762
OK, I found the info I needed... however I don't think the two computers are compatible. The wiring is just too different between the two trucks. Several sensors for the Dakota (like the electric fan) are not even an option on a Ram. Does any one have a 5.9l computer for a Dakota? I will post that question as a thread and see what happens.
Old Sep 1, 2010 | 09:41 PM
Derek2002's Avatar
Derek2002
Sorry it didn't work out for you.There are several other diagrams if needed.
