revs acting weird
Old Sep 1, 2010 | 05:19 PM
Josh Abels's Avatar
Josh Abels
Default revs acting weird
So its been goin on for a bit but I haven't payed attention to it much but when I start up my truck for the first time the revs seem to go up and down like 250-500 revs doesn't matter if AC is on or off but I'm wondering if its a symptom of possibly going soon?
Video coming soon just waiting on YouTube to upload it.
Old Sep 1, 2010 | 05:23 PM
dodgeramguy85's Avatar
dodgeramguy85
Tps could be causing it our 04 jeep was doing the same thing. Does it only happen on first start up only or will it do it like if you are stopped somewhere?
Old Sep 1, 2010 | 05:26 PM
Josh Abels's Avatar
Josh Abels
http://m.youtube.com/index?desktop_u...&v=IzVaxM8Veew
Old Sep 1, 2010 | 05:30 PM
dodgeramguy85
link is messed up
Old Sep 1, 2010 | 05:36 PM
Josh Abels's Avatar
Josh Abels
Damn ill have to wait till I get home round 8 in school on my phone
Old Sep 1, 2010 | 05:46 PM
Josh Abels's Avatar
Josh Abels
http://www.youtube.com/watch?v=IzVaxM8Veew
Old Sep 1, 2010 | 05:57 PM
thunder98110's Avatar
thunder98110
i would start with the easiest.....TPS
Old Sep 1, 2010 | 07:00 PM
Rantz's Avatar
Rantz
How do the vac lines look under the hood?
Old Sep 1, 2010 | 09:12 PM
Josh Abels's Avatar
Josh Abels
If they look anything like the last time I checked em they should be good
Old Sep 2, 2010 | 06:12 PM
Derek2002's Avatar
Derek2002
Sounds kinda like you IAC to me.I don't think there is a way to test it on a dakota.But you can test the the TPS with a volt meter if you have one.The middle wire is the output signal wire.It should read around .26 volts at idle and around 4.49 at WOT.The TPS doesn't have a resistance test,Which is the easiest, but check the output voltage and see what you come up with.
