changin the diff oil as i type
Im doing mine this week sometime I have so much I want to do to my truck lol I ended up just wanting to paint my diff cover too then I started to paint my axle and before I knew it I took of the bed and was painting the frame(first coat)
haha I dont get that carried away lol and yes my garage is still a mess!!!
I would like to get a nice powder coat on my diff cover, but I don't have a spare oven or the room for one (I live in an apartment) to cure it in. I bought the wireless powder coating gun, but I can only do objects small enough to fit in a toaster oven...
While you're at it, go ahead and paint the exhaust pipes with some VHT exhaust paint.
oh and please tell me u sanded down to bare metal before painting and just didn't paint over your rust
dude ur garage is still better than mine, its a two car but with all the crap my stepdad has in it, and his two work benches, fridge, freezer, and two motorcycles there is no way u could get a vehicle in there
Yes I sanded down took me 3 hrs just to do the driver side cause it was bad then to top it all off I added 3 coats of paint.
thats the beauty of living out in the country lol. I have a barn and 2 shops i can work in haha.
anyway before you takethe pumpkin off you there is a drain plug for the diff correct?
also should i spray all the gears and stuff with brake cleaner or something to clean em up?
When you do your diff change take all your bolts out execpt 1 at the top(just loosen it a bit) then pry at the bottom of the cover and let the oil drain out of it. Once done take the cover off and spray brake cleaner in the diff and wipe it out(I got 2 cans from napa for 5.00) but spray it out real good and wipe out as much as you can. Side note for you if you have any cuts on your hands try not to get brake cleaner on them if you do it will burn like a sob make sure to wash out afterwards. If your wondering brake cleaner is safe for your rear end wont hurt anything just helps to get the oill off of everything makes a big difference
Before brake cleaner see how its all black and nasty.
After
